Does it all the time now. Might be comeing from the primary.
Might be if you want some help, you could tell us what motorcycle you have, you know....Model, Year, Mileage, did the noises just start, when does it happen, you know...DESCRIBE IT.
Don`t expect us to read your mind, you gotta give us something to go on besides you hear a noise...
You are close to being ignored.....just sayin.
I get that in my knees and other joints when the weather changes and if I drink too much the night before; happens on the baggers as well as the Low Rider.
Pull off the primary cover and have a look.... I wouldn't drive it with a loud grinding noise...
Could be simple as your compensator bolt coming loose, or a broken primary chain tensioner.... or it might not be from the primary at all....
Gotta open up your primary and see what is, or is not, grinding in there..... it just takes some time, a little primary fluid, and maybe a new gasket...
