I've adjusted the screw 3 times, each time a half turn. Each time I'm starting to feel resistance at around half way on the lever. I have not touched the adjuster on the cable itself yet. See pic.
You say you haven't touched the adjustment at the handle? I thought that cable had to be completely slack to adjust the clutch basket. Without going to check my book I think I remember that if that cable is not completely slack you cannot get and accurate adjustment at the basket.
That's the first step in adjusting the clutch........
The cable was completely slack before I went to the basket. Those pictures are after the adjuster screw bac ked out 1/2 turn at the basket. The adjuster on the cable hasn't been touched yet.
Then I would follow Big Dave's advice... to make sure the ***** are seated in the ramp...
