2014 Hydraulic clutch
My problem is when I first get ready for a ride and after getting the bike warmed up a little and put it in first gear it makes a hellacious clunk, but after that, when shifting from neutral into first you can’t even tell it went into gear it’s so smooth. All the recalls have been done on the clutch. Using Harley formula + in the primary, at the correct level. Anyone else have problem? If so,
what can I do to make it engage nicely on first shift into first
I've read about all kinds of "solutions".
Hold the clutch in for 20-30 seconds before putting into gear.
Roll the bike backwards in neutral with the clutch engaged..
Engage clutch and give the throttle a couple of blips before putting into gear.
Try different fluids.
I'm sure there are others.
