mine are marked low and high beam too but i changed out the handlebars, and could not remember which was high and which was low. I assume the bottom bulb is the high beam?
2018 Street Glide FLHXS
Correct. If you look at the back of the reflector, "65W" is embossed next to the bottom bulb to indicate proper bulb orientation.
Hard to believe the plugs are interchangeable but if they are, just connect everything and turn on the power. Shine the light on a wall, if the beam goes up when high beam is selected you were lucky. If the beam goes down, move each plug to the other bulb and try again.
