Rear wheel noise
Old 06-30-2019 | 11:25 AM
MCorso's Avatar
MCorso
Stage III
Default Rear wheel noise
My '09 ultra is making a squeaky chirping noise from the rear wheel. It only does it after the bike runs for a few miles, then it gets progressively louder, is is my belt or a bearing?
Old 06-30-2019 | 12:45 PM
leachman's Avatar
leachman
It is my understanding that the squeak is coming from the rubber isolate for the slip-ons.
Old 06-30-2019 | 01:40 PM
Bass Player's Avatar
Bass Player
Spray some WD in the rear rubber muffler mounts and see if it stops? If it does replace them it's a no brainer. If it doesn't stop check you belt.
Old 06-30-2019 | 02:01 PM
MCorso's Avatar
MCorso
Stage III
It only does it when the bike is moving. It's clearly an issue with the wheel.
Old 06-30-2019 | 03:21 PM
IrishHogtrotter's Avatar
IrishHogtrotter
Check the belt is tightened correctly. A too tight belt will make it squeak. Also inspect the pully for wear.
I had same issue and replaced the pulley and cured the squeak. You can moisten the belt with soapy water and then run for a few miles to see if the squeak goes away, when it dries the squeak will come back, but at least you will know it's a belt isuue
Dieselss (06-30-2019)
Old 06-30-2019 | 09:51 PM
cncmike's Avatar
cncmike
It could be the rubber muffler isolators. Some grease or lube spray and ride it again will rule that out. The other thing it can be is the rear wheel bearings. But I see you have a 2009 like me. If the belt and rear pulley are original and have a good amount of miles it could be they need to be replaced. Especially if it only makes noise when you let off the throttle. My belt wasn't damaged and had all the teeth but they weren't exactly round any more. The front and back of the teeth were flattened. And the rear sprocket is only aluminum and mine was obviously worn. The front sprocket is steel and doesn't really wear. Now it is silent.
Old 07-01-2019 | 07:28 AM
MCorso's Avatar
MCorso
Stage III
I took a look at the pulley and it is all chewed up. I'm thinking this could be the issue.
craigpell1
08-20-2017 09:44 AM
BuddyK
Wheels/Tires
06-24-2015 11:19 AM
Rick Fowler
Wheels/Tires
04-28-2013 04:33 PM
sporty63
06-22-2012 09:45 AM
karatekid77
05-05-2008 10:48 AM
Quick Reply: Rear wheel noise
