Inner primary Bearing tool
I just did my 2000 tc88 inners with the Harbor Freight bearing puller kit with the slide hammer
the kit has 4 different size arbors for different size bearings..it worked great! $72.00 for the kit...i put the bearings in the freezer for a couple of hours and they tapped right in with a socket.
i did the outer bearings in the cam plate by pressing them out with my vise...i heated the plate a little with a propane torch...they pressed right out...also did the freezer method for the bearings AND the cam ...worked friggin awesome!!!
i dont know if your year bike has the same setup as mine... but it worked for me!
I had bought a gloss black inner primary I want to use but would you recommend nothing it with this mark on the bore where the bearing sits ?
![](https://cimg5.ibsrv.net/gimg/www.hdforums.com-vbulletin/2000x1504/20190709_112642_a217c71b27681abcc3c8a0b9a6aa4bfeb05d2b83.jpg)
soulpatch
07-14-2019 11:42 AM
speakerfritz
08-07-2011 12:34 PM
