Question for the electrical gurus out there
So if you jump an installed battery on a touring bike (pick one) you are usually safe if you do without the donor vehicle idling. The cranking amps are the close to the bikes battery capacity. Now what about jump starting from the battery booster packs, claiming 1,000 amps, any harm being done? My cars alternator will crank 150 amps, is CCA a different animal? Maybe I'm over thinking this.
If someone was buying a new battery to put in _____, would you tell them not to buy one bigger than stock?
Amps are a factor of demand, not supply. The danger in jumping a motorcycle with a running boost vehicle isn't the amps. It's the remote possibility that the boost vehicle has a bad voltage regulator, which could send way too high voltage into the motorcycle's electrical system, which could cause significant damage. The boost vehicle can in fact be running as long as the voltage is correct. It could have a 20000 amp capacity, and it would harm nothing.
The following 2 users liked this post by Brewmany:
crazytown (06-07-2019),
Dan89FLSTC (06-07-2019)
Donor vehicle should be OFF.
If not then the added demand of disabled vehicle while cranking could cause donor vehicle to compensate voltage thus presenting a sudden over voltage situation on disabled.
Most likely due to the disabled vehicles inability to shunt excess voltage..
As explained before it is not about amps but volts and how fast can excess volts be shunted.
The days of raising the RPM's on the donor vehicle while cranking the dead vehicle are over.
