Fuel injector recall?
Old 07-10-2007 | 03:43 PM
blueflame's Avatar
blueflame
3rd Gear
Default Fuel injector recall?
Has anyone caught wind of a fuel injector recall on the '06 dressers?
Old 07-10-2007 | 03:50 PM
Biggzed's Avatar
Biggzed
Default RE: Fuel injector recall?
It wasn't a recall, it was a Service Bulletin. If your bike exhibited certain rideability problems (can't remember which off the top of my head) the dealer would upgrade fromt he stock 8 degree injectors to the 25 degree injectors
Old 07-10-2007 | 03:58 PM
petemac's Avatar
petemac
Good luck getting them swapped. The dealer will put you through the meat grinder and throwso muchBS at you to get you to go away, that you'd rather have the injector problem than the stress of dealing with these meatheads.
Old 07-10-2007 | 04:03 PM
06ultra's Avatar
06ultra
My dealer changed mine at my 5000 mile service, no questions asked.
Old 07-10-2007 | 04:13 PM
petemac's Avatar
petemac
Did you have a SERT or PC?
ORIGINAL: 06ultra
Old 07-10-2007 | 05:00 PM
mtkjr03's Avatar
mtkjr03
I had a problem where it would stall when I wen to take off. If it warmed up for 1 minute or 1 hour it did the same. Almost dropped it a couple times. Told the dealer and they changed. Did call 2 other dealers before I took it to where I bought and they both tried to give me sh*!.
Old 07-10-2007 | 05:04 PM
murph3204's Avatar
murph3204
They replaced mine at the 1k service. I have the SE download and they didn't give me any trouble at all.
Old 07-10-2007 | 05:13 PM
Sreynold1's Avatar
Sreynold1
Tested the water at the dealership...Told them bike coughed and almost died. I knew about the injector issue, I just played stupid. When I went to pick up bike, they had changed the injectors based on the service bulletin. NOT ALL DEALERSHIPS ARE RUN BY DICKS!!! Mine is great and has been for the last 15 years of dealing with them.
Old 07-10-2007 | 05:19 PM
Thunderbolts's Avatar
Thunderbolts
Mine was done at about the same time from my dealer with no questions asked.
ORIGINAL: petemac
ORIGINAL: 06ultra
Old 07-15-2007 | 10:31 PM
mllkn6's Avatar
mllkn6
Does the 25 degree injectors make any difference in performance over the 8 degree? thanks
