08 Ultra Classic runs great but will not restart
Old 05-29-2019 | 12:31 PM
Ben221's Avatar
Ben221
Does the bike have a FP3 installed? If so take it out and try it.
Old 05-30-2019 | 09:21 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Check the connections to the ignition coil. You are not getting spark. Also check to see that your wires and plugs are good and that they are properly seated.
Old 05-31-2019 | 02:53 PM
vanceandhines's Avatar
vanceandhines
Former Sponsor
I would see if you can run a fuel pressure check, but my intuition says that you've likely got an issue with the Crankshaft Position sensor. I'd pull the sensor from the case to visually inspect it for debris, as it can/will get covered in metal shavings causing an intermittent starting issue since it's not reading the crankshaft's teeth properly. If it's covered, clean it off, reinstall, and give it a go.
Old 06-05-2019 | 01:21 PM
Nimrod810's Avatar
Nimrod810
Stage IV
ISSUE RESOLVED!!!
I had to ride it a few days to make sure it was truly repaired. It was a fuel pressure issue. Tech duplicated the issue and said fuel pressure after the bike got hot was 28 lbs. They replaced the fuel pump regulator and housing (which were warped due to the heat from the engine...poor engineering) and for good measure replaced the fuel filter. After repair but before reconnecting all the fuel lines, the tech turned the ignition on and fuel shot across the shop. LOL Rode it home from the Harley store on Friday, no issues restarting. 360 miles Saturday with four restarts, no issues. Rode Sunday, Monday and Tuesday..no issues. I'm calling it fixed!!!
Thanks for all the suggestions, Gents. Much appreciated.
The following 4 users liked this post by Nimrod810:
Candler (06-05-2019), Cogswell (06-05-2019), qf4phlyer (06-05-2019), Vernal (06-05-2019)
Old 06-05-2019 | 01:36 PM
danzio's Avatar
danzio
Originally Posted by Nimrod810
ISSUE RESOLVED!!!
Glad you got it resolved. I think many have replaced their compensators only to later find and fix the cause.
Nimrod810 (06-05-2019)
Old 06-05-2019 | 05:12 PM
Zerk's Avatar
Zerk
deleting. But I did guess right if anyone believes me.
Old 06-05-2019 | 07:01 PM
whyrzwaldo's Avatar
whyrzwaldo
Hey thanks for the feedback glad you got it resolved!
Old 06-05-2019 | 08:23 PM
miner999r's Avatar
miner999r
Good to hear you got it running.
Just as an after thought an old simple and cheap way of checking whether or not you have a spark was to pull the plugs and re-connect the plug wires and ground the plug against the fins, crank the engine and see if there was a spark. Make sure your fingers are not making a connection and don't do it close to the spark plug hole.
Might want to check with the shop to see if this is might be a bad thing to do with ECM controlled engines.
Old 06-05-2019 | 08:48 PM
Zerk's Avatar
Zerk
I would never talk to that shop again. Unless I am missing somethin WTF did they sell him a compensator?? What did that have to do with hot starts?
My truck did the same thing, fuel pressure reg too.
FXDBij
05-29-2019 12:56 AM
Mayhemryder
Electrical/Lighting/Alarm
03-17-2015 07:10 AM
Shotglass
11-12-2010 10:01 AM
Win_Brad
09-22-2009 06:58 PM
pop1
09-14-2008 02:37 PM
Quick Reply: 08 Ultra Classic runs great but will not restart
