Rear brake switch connector issues
Gents,
recebtly, my rear tail light and turn signals stopped working. After checking I found it to be the fuse. Replaced it and all good. But then when I hit the rear brake. Popped fuse again.
Checked underneath and say one of the connectors dangling. Reconnected it and good to go.... for a few miles. Same issue. I can’t get the thing to stay in place (connected). It looks like my exhaust bracket (bassani 2-1) is rubbing in it and causing it to come loose.
Any tips?? I’m at a loss here.
Thanks!
Thanks!
Received 5,290 Likes
JonnyVegas (05-27-2019)
Mine switch was replaced on recall some years back might want to check it out.
HARLEY DAVIDSON TOURING ( 06/06/2008 – 16/09/2011) DEFECT: The rear brake lamp switch may become exposed to temperatures that degrade its performance. This condition may affect brake lamp function and /or cause a brake fluid leak through the rear brake switch affecting rear brake performance.
Remedy: Recall the machines that are likely to be affected to check and where necessary replace the rear brake lamp switch using the recall kit.
Recall Launch Date: 23/01/2012 Recall No: RM/2011/031
