Inner Primary job
Old 05-27-2019 | 07:07 PM
miketv84's Avatar
miketv84
Originally Posted by dawg
You probably just have a shifter shaft leak and may not have other issues. Hard tellin’ not seein’ until you take it off though. HD sells a primary seal kit now to make it easy (black seal).
Cool Yeah I was going to order that kit from HD along with a gloss black shifter lever.
Old 06-05-2019 | 04:03 PM
Heath Townson's Avatar
Heath Townson
Stage I
I was wandering how the bearings on the other end of the shaft come out? I'm a 2007 model ?
Old 06-05-2019 | 04:23 PM
dawg's Avatar
dawg
Which shaft are you inquiring about, the main shaft?
Old 06-05-2019 | 05:04 PM
Zerk's Avatar
Zerk
Tranny shifter shafts have been a leaker for Harley. Got better when they went to double lip seal around 2005. Lots of work to get at $1.5 seal. So last time I had primary off I chaged it, was around 57k. Was about to fall apart. When it gets to that point real hard to get a grip to get out, and real hard to clean out hole.
Was installed backwards at the factory.
My 07 had 2 inner primary bearings fail. So this time I went to a one piece Baker. Will see if better. Had to remove race from shaft. My 01, replaced the bearing at 34k, since I had it open. 78k still good. Bad bearings from Harley? Other issues?
FroggyFatBoy
47
06-07-2015 05:57 AM
bobbyjoes
12-29-2012 01:11 PM
scottdoege
10-23-2011 08:48 AM
PotterBoy
09-07-2011 09:55 PM
z28scotty
08-16-2008 07:52 AM
Quick Reply: Inner Primary job
