Dealer info misguided??
Just scheduled my 5K service on my 07 RK. Asked about performance upgrades (pipes, fuel mgt., ac). Service mgr said that none of those upgrades will reduce the engine heat. Also said that just by adding the SE pipes performance will be improved, don't need ac or SERT, etc. That goes against everything I've read on this forum. Should I look for another dealer for the service?
RE: Dealer info misguided??
Performance of your bike can be subjective - pipes alone will improve its performance somewhat, however, further steps will also have an effect. Some have been very disappointed with their cost vs performance ratio - perhaps your dealer has had some of those instances and wants to be realistic. Really, there are almost limitless mods you can do to the engine - cams, bigger bores, fuel management, head work, better valve springs, lighter pushrods, etc, etc. However, money is a factor and one that you must consider. Is it really worth $1000-2000 to gain 10-20 HP. Some will say yes, others will stay stock since when they trade or sell, they'll loose every cent. Try another dealer and see what he says - just always ask for the bottom line and what to expect.
ORIGINAL: Beancount1
Thanks for the great responses. It's funny though - the service manager says all I need is the slip ons, while the parts guy in the same dealership said I should do all three. I'm going with the SE slip ons for now and see how it performs. If it doesn't substantially improve I'll do the ac and the download later.
I'll take his word for it.
A problem with many, not all,"old school" Harley people is that they spent their motorcycle lives tuning carbureted bikes--I especially noticed that Mac57's service manager apparently did not mention a SERT, but did mention the PCIII and other piggyback fuel management systems. And, frankly, their learning curves stopped short of fully understanding the SERT and what a wonderful tuning tool it is. Check-out Doc1's recent polls on SERT tuning at HD dealerships for confirmation.
My EFI 88" stock '04 EG with Rinehart TD's, SE a/c, and a competentSERT tune went from a 60 hp/70 ft. lbs torquemotor to a 75 hp/80 torquemotor. A 25% increase in hp is defintely a significant difference in my book.
Would I spend the money to buy a quality fuel mangament product if I was just changing mufflers? Probably not.
But I also wouldn't wait to buy a qualityfuel management system until I did a big bore, cam swap, etc. if I wanted an intermediate, and more affordable, performance bump on my bike--and I am glad Ididn't. JMHO.
The first things I install on a new bike are mufflers, AC, and EFI mod--and all at once.
The slip ons will do pretty much nothing at all for the heat. If you are putting them on for sound or just to change the look then they will do that. The AC will really help with the sound as it will allow a ton more air in. You will need to do something with the ECM though as it will also make it run way too lean.......
