clutch creep
Received 8,296 Likes
Make sure your clutch is adjusted per the manual. Get the manual if you don't have one..... Primary oil can have an effect of clutch operation. Do not use Syn 3 in your primary. A clutch manufacturer told me the slickness/slippery additives may cause clutch slippage. Use an oil designed for primary use. Formula + is good. I have used Type F auto trans fluid with no issues. Don't panic....what's in that primary that may not be in an automatic trans?? But regardless use an oil designed for primary. That should eliminate slippage or difficulty finding neutral.
Ddieselsmoke (05-26-2019)
I had an issue with a bad Iso grip. So I temporarily reinstalled the stock grips until I received the new grips.
They were much thicker, this prevented the clutch lever from being completely depressed at the present adjustment.
I just had to adjust the clutch pack "IN" a 1/4 turn then adjust it again for the new grips.
