MM to Carb Conversion
Old 06-06-2019 | 02:31 PM
Tired's Avatar
Tired
Received 4,823 Likes on 1,762 Posts
Can you measure the width difference between the MM and Mik manifolds? If it's a relatively small difference I'd lay some sandpaper down on a hard flat surface and take the Mik down to match it. Equally L&R of course. It's not unheard of to need to do that. The heads or jugs may have been cut and the MM may have been adjusted for it.
Just guessing here.
Old 06-06-2019 | 02:35 PM
JakePie's Avatar
JakePie
I thought it was a defective manifold as well, but Mikuni was kind enough to send me another to test that. It was also out of a separate batch to ensure they would not be the same. I am going to test fit a stock manifold to see if everything fits, and measure it against the Mikuni.
Old 06-07-2019 | 06:19 AM
jeeper101's Avatar
jeeper101
Originally Posted by Ironhandjohn
I seem to be one of the few who have a trouble-free MM system, maybe I should save the number of a good towing company in my phone.
I've read in several places that MM equipped bikes like it simple. Once you start changing heads, programmers and cams they start with the shenanigans.
I don't plan on building the engine so I hope mine keeps behaving for years to come
Old 06-07-2019 | 06:57 AM
Dehammer's Avatar
Dehammer
Received 2,667 Likes on 1,348 Posts
Mine was quirky which was all the excuse I needed to put a carb on it.
As self reliant as I try to be to keep it on the road I consider a AAA membership mandatory. Last Halloween I blew a tire and needed a tow and my towing company took the night off.
Old 06-07-2019 | 09:09 AM
Ironhandjohn's Avatar
Ironhandjohn
I hear you; 850 pounds is a lot of metal to push down the size of the road.
Old 06-07-2019 | 09:23 AM
hattitude's Avatar
hattitude
Received 8,293 Likes on 4,452 Posts
It will be interesting to see how the OEM manifold measures up..... Those Mikuni manifolds should fit...
Old 06-07-2019 | 10:55 PM
JakePie's Avatar
JakePie
OEM manifold fits like a dream. Not quite sure why the Mikuni was off the slightest, but I am not going to worry about it at this point. I was able to fire the bike quickly and it had a hard time staying running. Definitely still need to play with it to get it running good.
hattitude (06-07-2019)
Old 06-07-2019 | 10:56 PM
JakePie's Avatar
JakePie
Originally Posted by Rick Hard
How did it get to 98ci? An S&S kit?
May be it's something else with shorter cylinders?
I believe S&S does make a 98 kit, but mine came from Hammer Performance. Dan was great to work with and the bike made great power.
Old 06-09-2019 | 08:09 PM
JakePie's Avatar
JakePie
I picked up a stock manifold and it fits like a glove. I completely forgot to take measurements to understand the difference, but I was too excited to get it mounted.
Tcmuzzy88
Exhaust System Topics
08-07-2020 12:43 PM
pegskraper
Engine Mechanical Topics
19
01-16-2017 06:33 PM
parts eeter
07-30-2014 01:27 PM
rottie
03-27-2010 09:42 PM
droff85
Ironhead
03-13-2009 12:02 PM
Quick Reply: MM to Carb Conversion
