New wires and bars no throttle response
got a 2010 ultra classic replaced the bars and got all new wiring well now I have no throttle response at all bike starts an runs just no throttle and ive already looked 20 times the wires are all correct and I've already checked the module behind air filter too and its still good and intact ... Any ideas on what it May be
Are you positive that you have the right side grip seated fully to engage the plastic teeth of the TBW sensor and the mating teeth down in the grip? ask me how I know, lol.
Did you pull the wire in using the green plug, and by chance pull a wire loose?
I would also check to see if the TBW sensor is working by unplugging it near the risers and using a multimeter to read the change as you twist the sensor/grip.
wires in that green plug are a common problem. I ended up cutting it out an direct wiring it. just watch since there's 2 wires of each color off the grip sensor one in black wrap an one in yellow. if this is the problem it will give codes an turn on the CEL
https://www.roadglide.org/24-control...al-wiring.html
No codes make sure the grip is engaged.
