2003 Road King Belt guard
I noticed on my 2003 RK that the rubber flap on the drive belt guard is between the tire and belt. It is a tight fit between the tire, I would say rubbing on the tire. Should the rubber flap be between the tire and belt or should the rubber flap be in a different position? Thanks for the help!
What tires are you running? When I run Metzeler 888 WWW's on my 03 RK the rubber shirt will rub on the WWW and leave a dark mark. With the Dunlop D402's, no problem. I actually checked the difference in width between the two and the 888's are definitely a little wider causing the issue. I notched the rubber just a bit and now all is good.
