Phone cubby on SGS
Old 05-17-2019 | 08:44 AM
BrandonSmith's Avatar
BrandonSmith
I actually use a 180-degree cable all the time
Amazon Amazon
I don't like the stock cable that just sticks straight out. I've not experienced a situation where this 180-degree cable has been an issue.
Old 05-17-2019 | 11:28 AM
Sparkee...'s Avatar
Sparkee...
I just got my 2019 Ultra Limited. Not a lot of thought went into implementing CarPlay. There is no way my iPhone 7+ will fit in the little cubby hole. My old X-Grip will also not work on the bars with the hydraulic clutch so I'm not sure if I'm going to get a new X-Grip or run a USB extension back into the tour pack. Either way I plan on running the lightning cable up to the handle bars or into the tour pak. I may use a small un-powered USB hub in the fairing to keep the USB port in the cubby hole for software updates. We'll see if the system will support both the iPhone and a thumb drive connected. I could leave the thumb drive connected for tunes when the iPhone is not.
Old 05-17-2019 | 12:09 PM
RichM752's Avatar
RichM752
I keep my phone in my jacket pocket. I use the cubby hole for reading specs and insurance/registration papers.
Old 05-17-2019 | 12:29 PM
BrandonSmith
You can use the X-Grip, just need the $10 ball mount that I have that screws into the handlebar control mount (you can see it installed here: https://www.hdforums.com/forum/milwa...l#post16125089.
I also installed a unpowered 4-port USB hub in my fairing and it has worked great through the Texas summer charging my phone, my wife's phone, and playing music off a usb stick all at the same time (you can see it installed here: https://www.hdforums.com/forum/milwa...l#post16161112
sulli
Audio Systems
15
07-20-2020 03:07 PM
DLW_FLHTC
2014-2023 Touring Models
02-29-2016 09:41 PM
Rockrivr1
29
08-04-2014 07:09 PM
Aragorn
16
03-29-2014 03:48 PM
Nicky Pass
03-31-2012 07:36 PM
Quick Reply: Phone cubby on SGS
