Wrong exhaust gasket??
This is my first time installing exhaust. First time replacing gaskets. I had heard that these Rinehart true duals should be used with the S.E. gasket. I told the girl at the parts counter that I needed eye S.E. exhaust gaskets.
2005 Ultra Classic.
I get home and this is what I’ve got.
Seems like they are much thicker than what I thought the S.E. gasket was. In pictures and ideas it seems like a thin, flat band.
Does the thickness of this gasket compensate for the smaller diameter? Will it smash and expand, or is it the wrong damn part?
Thsnks for any help.
Part number 65900011
Seems like I remember other SE. exhaust gaskets I’ve seen are much thinner than this..
Too small, or will it get smashed and expand?
Harley part number. Anyone know of a fitment list for this part?
2005 Ultra Classic.
According to HD, the thin ones are for performance pipes and are not fitted in like the thick ones and they are supposed to improve flow.
Whenever I ask for exhaust gaskets at the local dealer, they always give me the thick ones and I never gave it another thought. Maybe I should try the SE performance ones on this engine with these Rineharts next time I have them off...
Unless I hear from somebody on what exactly these gaskets are, I’ll go next week and get some OEM ones. I would like to have had the pipes installed today. Oh well.
Dies the picture show how small diameter those gaskets are? I took the picture, so I see it well, but other s may not.
I would think that any gasket design would fit tighter than that. I wonder if it is for a different engine. There is almost ⅛” gap between outside of gasket and the exhaust port wall.
I'm installing a fuel moto pipe...I pulled the heads an had them freshened up....the guy that did the heads recommended I use some of the thinner aftermarket ones so they don't squish an block flow. I ordered James an when I got them they look pretty small. I might have to get another set an use 2 per port.
