Leaking front master cylinder cover?
Old 04-29-2019, 07:44 PM
K Melancon's Avatar
K Melancon
K Melancon is offline
If you over tighten the screws that can make it leak. Get a new gasket and tighten to spec.
Old 04-29-2019, 07:57 PM
pgrchaplain's Avatar
pgrchaplain
pgrchaplain is offline
COVER ALL YOUR PAINTED PARTS BEFORE REMOVING THE COVER!!!!!!! Brake Fluid is hard on Paint!
Old 04-29-2019, 08:00 PM
Jeff Dodson's Avatar
Jeff Dodson
Jeff Dodson is offline
Actually, HD does make a fix. Replace the top. It's a $25. And a PLASTIC COVER over the rubber and hard plastic inner. Prevents the corroding on the cap.
Old 04-29-2019, 08:04 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,530 Likes on 1,425 Posts
As mentioned, do what you have to, to get the reservoir level as you can before you take the lid off. Make sure you have the correct brake fluid that your bike calls for, may be marked on the brake system. Good luck!
Old 04-29-2019, 08:21 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,867 Likes on 2,555 Posts
The screws typically get tightened to 8 inch pounds. that's not much, just enough to make the gasket barely bulge out between the two surfaces. Don't forget, PROTECT your painted surfaces.
oleksa (06-10-2024)
Old 04-30-2019, 03:32 PM
470004's Avatar
470004
470004 is online now
Received 16,345 Likes on 6,767 Posts
Agree.
Old 04-30-2019, 04:35 PM
xltjim's Avatar
xltjim
xltjim is offline
Agree what has been recommended so far. I will offer this up as a suggestion. If you take that rubber gasket off. Take the precautions mentioned by turning the bars to get reservoir level and cover any paint. Remove the cover. Get some rubbing alcohol and really clean that gasket. Really, really, massage the heck out of that gasket with your fingers. Clean the lid and mating surface as well with the alcohol being careful not to contaminate the fluid. Reassemble and tighten very gently. You want it snug but not enough to cause the gasket to bulge. I have done this a couple times when they said I couldn't get just the gasket and wanted 25 bux for new lid/gasket. You can also lightly sand any bubbled paint and touch up with a small detail brush. Worked for me and my friend that had same problem - his was rear brake. Certainly worth a shot and got nothing to lose. Good luck. Jim
albngore
03-04-2017 09:22 AM
78lowshovel
Shovelhead
12-01-2014 11:38 AM
BobbyVera
06-30-2013 07:51 PM
DeiGratia
04-30-2012 01:14 PM
Drifting Texas
02-29-2008 09:08 PM
Quick Reply: Leaking front master cylinder cover?
