How much would leak...?
Old 04-28-2019, 11:35 AM
Essthreetee's Avatar
Essthreetee
Essthreetee is offline
Originally Posted by dawg
Were it me, I’d buy the inner primary gasket kit which includes everything you need to pull the inner primary. While taking it down, I’d check the status of the comp, chain tensioner, shift shaft seal, IPB, race and mainshaft seal and replace as necessary. Especially since you’re the third owner you can get a better look at everything inside if you’ve never been in it.
Ok. So then this adds another several questions. I have pretty good mechanic ability and don’t fear taking apart and putting back together, but I don’t have the knowledge to know what I would be looking at as far as “checking” stuff. I have watched several videos of comp replacement and am very confident I could do that. But how would I know if it is bad? Or the shaft seal? Or the inner primary bearing? Etc.
Sorry if I sound ignorant, just don’t want to throw unnecessary money at it...if I can avoid it.
Thanks in in advance for your help and input.
Old 04-28-2019, 11:44 AM
skinman13's Avatar
skinman13
skinman13 is offline
Your question is the bane of every new wrench or old wrench in new territory...
What am I looking at, how does it work, what is right, what is wrong, and how will I be able to tell...
There is no one answer. Experience and mechanical ability help, of course, but sometimes you just have to go with your instinct on what looks right and wrong, and if that fails, get help.
Old 04-28-2019, 12:05 PM
Solospec's Avatar
Solospec
Solospec is offline
Before you start tearing into your bike I would get a factory service manual so everything gets put back together correctly. My bike was dripping from the drain plug but it was actually my inner primary bearing seal. Is it dripping from a certain area? Good luck with finding the leak.
Phil
Old 04-28-2019, 12:58 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,979 Likes on 4,171 Posts
Once you get the clutch hub off, that huge inner primary roller bearing is visible. Need to turn shaft of course to inspect. When I get this far, I drop rear wheel out, pull cog drive belt fwd off drive cog pulley sprocket. Then you can spin input shaft and fill what transmission fills like. I shift up thru the gears . If they are all smooth, no catches and fill the same, you can assume the main drive gear bearing is ok along with that double row needle bearings on the inner shaft.
Turn the clutch hub around and spin and check condition of ***** and race.
Add a signature line similar to my bike line on year model and letters.
doc308
Shovelhead
06-30-2019 07:38 PM
Harley5
06-16-2019 11:44 AM
06Sportster1200
11-01-2011 01:20 PM
2in2outhd
05-22-2011 07:46 PM
DBLRRCN
03-11-2007 11:45 PM
Quick Reply: How much would leak...?
