Installing 10" yaffe bagger bars
Old 04-24-2019, 06:59 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
GriffinDenim13FLHX is offline
Thank you for all the help. Looks like I better order a new clutch , brake lines, and an electrical extension kit just to make sure. Looking forward to the weekend challenge.
Old 04-24-2019, 08:58 AM
Inop's Avatar
Inop
Inop is offline
I installed 10" Meat hooks which are similar to the Yaffe, but I hear the Yaffe's are a bit taller. Anyways the stock wiring was long enough with no additions. I did replace the clutch cable because it was a little tight and I wasn't comfortable with that.
Old 04-24-2019, 11:25 AM
skinman13's Avatar
skinman13
skinman13 is offline
I installed Paul Yaffe 10" Classic Ape Hanger Handlebars on my '03 Ultra Annie. The electrical wire length was sufficient but I did have to replace the brake line, and clutch and throttle cables. I used modular Magnum brake lines, MoCo Diamondblack +4" clutch cable, and Hill Country Customs +4" throttle cables with the cruise control roll-off switch.
Old 04-24-2019, 05:32 PM
memphisharley's Avatar
memphisharley
memphisharley is offline
Veteran: Marine Corp
just a FYI, I did not have to swap my brake cable. I did purchase a +4 clutch cable but didn't like how tight it fit so I ordered a +6 and it fit perfectly.
Old 04-24-2019, 08:00 PM
GriffinDenim13FLHX
Ok cool appreciate the tips on that. I just bought the +6 brake,clutch and, wire extensions. This way there are no surprises .
Old 04-27-2019, 09:31 AM
Dew Me's Avatar
Dew Me
Dew Me is offline
Not sure if any wire or cable lengths are different between 9 and 13, but I did 10" PYO MBB's and left wires and brake line stock.
I did +2 on clutch cable. It was enough, but I did reroute it a bit. I suppose +4 wouldn't hurt,
Be patient. You will push/pull countless times as you slowly get the wires through. Pushing seemed more important than pulling.
Conduit lube works good but is messy. There is a spray conduit lube now that is much less messy.
Get some quality shrink tubing.
Pull with a rope or swing that will be strong enough and also won't stretch. So Nylon isn't a good choice. I went kevlar string, but a weedwacker twine, picture hanger rope, or thick fishing line, can all work.
Watch some videos.
You can use a paperclip to get wires out of connectors. There is a tool you can buy instead if you want. (3rd time doing the job I finally bought the tool and glad I did. Cheap on eBay)
Assuming TBW assemblies are still the same as 09, I think it is worth it to buy the SE TBW for a hundred bucks. It has longer wires and doesn't have the green connector in the middle that makes things more difficult.
Buy poly bar bushings to replace the stock ones.
Blow string through initially with compressed air, or attach a little nut to it and angle bars around till nut comes out other end.
Take pictures of wires b4 removing them from connectors, and write down too. Many people mix up wires putting it back together.
GriffinDenim13FLHX (04-29-2019)
Old 04-27-2019, 10:07 AM
whiskeyfire's Avatar
whiskeyfire
whiskeyfire is offline
You should be able to cut a zip tie to make the brake line reach. One thing I'd do too is to put urethane bushings in while you have the bars off.
Old 04-29-2019, 10:25 PM
GriffinDenim13FLHX
Whew...
Old 04-29-2019, 10:28 PM
GriffinDenim13FLHX
Thank you to all for the tips and parts to get. All worked out well. Money saved and had an awesome time doing it.
Dew Me (04-30-2019)
Old 04-30-2019, 10:19 PM
GriffinDenim13FLHX
Work in progress...
Quick Reply: Installing 10" yaffe bagger bars
