95cu W/203 cams horsepower
Old 07-15-2007 | 10:26 PM
SpikeCT's Avatar
SpikeCT
Default RE: 95cu W/203 cams horsepower
damn that dont seem right.... I had 77 hp 80 lb/ft with BS, Rinehardt TD and PCIII..... I will get the dyno for the DTT soon.... I need to get it before we do my build on August 17th. I just want to see what the improvement was by going to the DTT...
capt42a's Avatar
capt42a
PhilM,
thanks for the help posting the dyno sheet, Peekaboo Bob, I'm considering different options on the exhaust, Supertrapp Supermegs possibly. What air/fuel ratio should I be looking for if it looks like I'm running on the lean side ? I'm located in west Tennessee (Jackson, TN.)
Old 07-15-2007 | 10:30 PM
mikeyflhti's Avatar
mikeyflhti
I don't think it is the duals, that is what I have on my bike. I agree with PhilM that it's lean. The chart is hard to read but it appears that the A/F ratio is around or above 14:1. When mine was tuned it was closer to 13.1:1. I'm no expert but I wouldn't think that the difference would cause the numbers to be that low.
Old 07-16-2007 | 02:18 AM
PapaTravis's Avatar
PapaTravis
I bet you are disappointed. I have a 88" bike with a carb. I was looking at a 95" or 98" kit. I hope you figure out what is up with those numbers, and post it on here, so I can see what to avoid. Question I have is, on www.nightrider.com , I have seen 95" get to the 100/100 numbers, how is this build any different than those?
Old 07-16-2007 | 08:10 AM
cobaltking's Avatar
cobaltking
The difference here and with a 100/100 build is cams and head work as well as tune. It all has to work together. You may have cams that work well with higher compression, but may only be running 9.5:1. Also, the heads may not be flowing well (stock HD heads are pretty bad, but with some work they can be quite good). I haven't taken my '06 carbed Road King to the dyno, but I figure I am close to 100hp and tq , after all I am running S&S 585's, Edelbrock heads and a super E, all at 10.25:1 . . . man, it moves . . .
Anyways, didn't mean to hijack the thread . . . but any 95 c.i. with 65 hp, seems bad to me . . . but would the A.F. affect the hp that badly . . . I mean 10 hp is a lot. Could it be timing as well?
79roadster
Engine Mechanical Topics
16
07-26-2019 08:46 AM
rperk60
10-06-2016 04:12 PM
roadchaser
Exhaust System Topics
10-02-2016 11:18 AM
richy rich
02-04-2009 01:48 PM
2fas4u2
11-13-2007 08:19 AM
Quick Reply: 95cu W/203 cams horsepower
