95cu W/203 cams horsepower
RE: 95cu W/203 cams horsepower
Same setup with V&H True Duals and Wild Pig mufflers. 77hp and 94tq I may do some head work this winter.
two dogs,did you do anything else toget 91hp? Most of the dyno charts I've seen give between 75 and 80 hp with a big bore and 203 cams. I'm just curious, ok, a little jealous too! I do like the tq curve on my bike though.
[IMG]local://upfiles/14641/0D53C9E3A22644D9B95C22324364BCCD.jpg[/IMG]
Hey Guy's,
I'm backfrom the dyno and pretty disappointed with the results. Max Hp - 65.96, max torque - 75.61, I'd post a picture of the dyno sheet but I haven't figured out the picture posting thing. I could e-mail the dyno sheet if someone would help with posting it.
capt42a
capt42a
Those numbers are not much different than a stock 88" motor. Something is not right. Is it possible you have a "before" dyno sheet?
If not, then you definitely need to find another tuner. Do the numbers fall off pretty early? Perhaps the motor is sumping. I'll send ya a PM & get your sheet posted.
Here's the Capt's dyno sheet...
In my opinion, it a bit on the lean side, but not enough to cause numbers this low. You're gonna have to get a 2nd opinion. Are you anywhere near northern GA?
[IMG]local://upfiles/8665/3F331E434AC9481486670DECEB48AAED.jpg[/IMG]
