V&H Slip-Ons???
RE: V&H Slip-Ons???
Typically if all you add is exhaust (slip ons)you do not need to remap but I have heard recommendations saying you should as well. When I put on the V&H Ovals I added the ac and sert to help reduce the engine temp a bit. It helped the heat, added a bunch of power and improved my fuel mileage to boot. I used a canned map on the sert and could probably get a bit more power if I dyno tuned it but it's running great so I'm leaving it alone.
If you canswing the complete setup I really think that's the best way to go.
RE: V&H Slip-Ons???
ORIGINAL: chesterbud
RE: V&H Slip-Ons???
The SERT is an interface used between your PC and the ECM on the bike. It allows you to modify the fuel map (usually to increase fuel mixture richness) to compensate for the ac and exhaust which due to increased airflow will lean the fuel mixture too much. SERT is a HD product and there are many others on the market like PCIII, Thundermax, Fuelpac etc.
I went with SERT (most expensive option) since it was HD and installed by my dealer. IMHO there is less of a chance that a warranty issue will arise if needed.
RE: V&H Slip-Ons???
Thanks, Chesterbud. Whichever route I go; just slipons or full exhaust system, I know if I try to do it myself I'll end up with parts left over (inexplicably) and the system not operating properly. So I'll prbably have HD put it all together. Which is a good argument then for using their SERT rather than another manufacturer.
RE: V&H Slip-Ons???
The slipons are super easy. You can't possibly have extra parts. The V&H ovals come with the mufflers, 2 clams, 2 bolts, 4 washers, 2 nuts.
Take the bags off. There will be 2 bolts holding the pipe to the bag bracket on each side. There will be 1 clamp on each pipe right at the end of the heat shield. Undo that. Then you will need to wiggle the muffler off the header pipe. Depending on how long you've had the stock, you may need to use some release oil on that portion. Wiggle the new slipon back on the header. Bolt the 3 bolts, wipe the pipe down with windex, you're done!
The instructions give you a step by step. Don't waste your money on having them install the slip ons. 30-60 minutes tops to switch them out.
I used ebay, americanclassicmotors. They have the best prices most of the time.
Paid $725.85 Free shipping
Ebay:
V&H Ovals $425.95
Ness Big Sucker $99.95
V&H FuelPak $199.95
Ebay:
V&H Ovals $425.95
V&H FuelPak $199.95
RE: V&H Slip-Ons???
It is a good idea to remap with a free flowing slipon like vh ovals, epa already has the 07 to lean, most other than SE street perfomace slipons from harley will lean her even more causing more than the already too much heat you will have. This could cause engine problems in super hot weather. The SE slipons sound good and can be used without worry.
