FP3 map for 12 street glide
The best map for your configuration will be the one within the app labeled for Twin Slash Rounds with your corresponding header system. The map was created at around the same elevation and should serve you well pending the baffles haven't been removed, then you'd likely need to run an AutoTune session.
Bryan
Brand Manager, Electronics
GalvTexGuy (04-01-2019)
vanceandhines (04-02-2019)
