TTS-100 Owners...Heavier Clutch??
Old 03-30-2019 | 05:34 AM
bklynbob's Avatar
bklynbob
Originally Posted by lh4x4
I know a long time engine builder that when a customer wouldn't spring for a heavy duty clutch with a build would just put ATF in the primary as the clutch would hold better.
What would it hurt to try that before rebuilding the clutch?
The newer compensators I’m vtold don’t wear well with ATF.
Old 03-30-2019 | 07:18 AM
Plow64's Avatar
Plow64
No slippage on my '15 Ltd with TTS-100, 2-1 exhaust, high flow AC, running Redline primary case oil and stock clutch.
JayStronghawk (06-09-2019)
Old 03-30-2019 | 08:13 AM
EdwardK's Avatar
EdwardK
How many miles on your clutch now? Indy smoked my clutch on the first test ride after bumping from a 96 to a 103 with cams but mine already had over 100,000 miles on it. He rebuilt the clutch and used a heavier spring. It's been fine ever since.
Unless an adjustment will stop the slipping, changing oil is a short term fix that may or may not work right off the bat anyway. If the plates aren't worn to bad, you may get away with just the heavier spring,
FYI - Heavier spring also means heavier clutch pull. If you don't want that and you have the money, look into the VPC clutches or ask the tuner for his advice.
Old 06-06-2019 | 11:52 PM
SnoRider's Avatar
SnoRider
Thanks all for the input!! For the guy that says TTS sucks....my dynotuner was working over my bike and it was a tricky one to get dialed in. On day 2 (which was a saturday) we were doing flight recording adjustments, I was there, my tuner was there of course and Steve Cole himself was there on the phone and working on my map from his computer. I say that beyond excellent service.
Old 06-07-2019 | 08:47 AM
skinman13's Avatar
skinman13
My stock clutch slipped when I first put this engine build on the road and I was all ready to go with a new clutch pack. But the clutch disks looked good and my project funds were running low so I decided to try the SE heavier clutch spring first and go from there. There has been no slipping since I changed the spring...but working the clutch in prolonged traffic can be a real **** on the hand arthritis.
Old 06-07-2019 | 05:48 PM
SkyMaster1's Avatar
SkyMaster1
im glad you had a better experience.
TTS (the turbo shop) \ (mastertune) will always be a no good POS thieving company and I will discourage anyone from dealing with them at every opportunity
Rumblin
Engine Mechanical Topics
15
01-29-2017 03:22 AM
Firemn17
General Topics/Tech Tips
07-21-2016 12:25 PM
beammeup
The Dyno Room
05-10-2016 08:43 AM
1931jamesw
05-13-2010 09:33 AM
Born2cure
11-21-2009 08:37 AM
Quick Reply: TTS-100 Owners...Heavier Clutch??
