Garage door opener??
Old 10-27-2005, 01:54 PM
Shotgun's Avatar
Shotgun
Shotgun is offline
Default RE: Garage door opener??
Birch,
It should not be a big deal. I hooked up the two wires from the Receiver (RX) to the same terminals as the existing push button on the opener and plugged it in. Turned on the bikes ignition switch to "Run" and had someone hold down the tiny "RESET" tab on the RX then switch your lights from low beam to high beam and back to low beam. Presto, it worked!
Shotgun
Old 11-10-2005, 09:44 AM
cereiter's Avatar
cereiter
cereiter is offline
5th Gear
Harley Davidson offers an opener that connects to your Hi/Lo headlight that sends the signal...I have one on my FL and it works great...cer
Old 11-10-2005, 10:06 AM
Wolfx's Avatar
Wolfx
Wolfx is offline
I just stuck some velcro to the one that we had in the car and its attached to the speedo enclosure.
Old 12-12-2005, 01:26 PM
FXDWG3's Avatar
FXDWG3
FXDWG3 is offline
ORIGINAL: cereiter
I just completed the Hi/Lo Switch Garage Door Opener Device on my FXDWG3. Man does it work slick. The kit covers a wide range of bikes. It pairs with the original receiver that came with the door opener.
Keith
Tin Man 1
07-06-2013 08:14 PM
Baggerzee
01-24-2011 10:38 AM
WVICEMAN
04-23-2009 10:28 PM
OneBlackFly
General Topics/Tech Tips
20
01-07-2009 09:03 AM
whiskeyrider
01-03-2008 10:36 AM
Quick Reply: Garage door opener??
