'19 FLHXS Handlebar Options
Just got my new '19 Street Glide Special. I'm short so I have had the bike lowered 1" front and rear and had a H-D Reach Seat installed. This allows me to comfortably Flat Foot when stopped. However, my arm reach to the handlebars is not comfortable causing me to lean forward slightly but noticably.
On my '18 Heritage, which was lowered and has a H-D Reach seat that allows me to Flat Foot it when stopped. Additionally, I was able to raise the stock handebars about 2" and back about 1 1/2" using a set of pull back risers that made my arm reach much more comfortable allowing me to sit up straight and still reach the grips with a slight bend at the elbows.
I'm not well versed about a SGS, so wondering what options I might have for getting my handlebars up a little and back a little. I know about H-D Reach Handlebars, but wondering if there are any other options. Not looking to put on tall apes. Stock style but slightly taller that can be pulled back some would be what I'm looking for.
Suggestions?
Suggestions?
Received 14,670 Likes
FrankEV (03-23-2019)
Before you spend any money, simply adjust your bars, to see if that works - in fact your dealer should have offered to do that for you IMHO, as part of making your bike fit, so visit them and ask them to do it! By all means look at changing bars if that doesn't work out, but try the free stuff first.
I don't find much, if any, difference in handleing with it lowered. I'm not an overly aggressive rider so I don't notice much difference. I suspect, like my lowered Heritage, I will scrape a little more often, mainly when 2 up, but that does not bother me. I've only scraped it once so far, and that was when it was still stock and during the test ride before I bought it. BTW, I actually find the front susppension is better than stock. No hint of dipping during stops.
The new Suspension Technologies suspension are gas filled and is a little stiffer than the stock setup. They originally had the rear shocks set at 3 turns. As I'm a "lightweight" this was a little too stiff and I cranked it down one full turn. Still slightly stiffer than stock but it feels good to me there. My Herritage is also stiff because my Lady is a little bit on the heavy side and if I don't keep the setting in the mid range the bike will bottom out a lot when 2 up.. I have not had her on the SGS yet so I'm not sure if the setting will be OK, but it feels much the same as my Heritage the way it is set right now.
What are the rise and pull back difference from stock?
Edit: did find they are available in Black.
Sat on an Ultra Limited Low with both the H-D Reach Seat and the H-D Reach Handlebars. That felt very good to me.
You can also go with the curved pull back riser. That’s what I did on my wife’s bike with the reach seat. Left the stock handlebars and it worked. It also saves you money since you don’t have to re run the wires in the bars. I believe the pull back both raises and pulls them back. That keeps the bars in the same position essentially. By raising them via the riser then adjusting them down to give you more pull back doesn’t really change the stock angle. Hope that made sense.
