Fairing installation
I recently purchased a Vector fairing with the preinstalled stereo and speakers system, for my 2018 Road King. It has a 3 prong plug on the bottom(2 male 1 female) I've been trying to locate where it would plug in, and have been unsuccessful. Does anyone know where to find the plug on the on the Harley? This is supposed to be a plug and play installation. However, they didn't supply any kind of instructions. I'd appreciate any help you have.
Unless something has changed dramatically you won't find that plug on the bike. The fairing should have come with the other side of the plug that you have to wire in to your bike. Mine is a different brand but if I recall correctly one wire to + side of battery for the memory in the stereo. One wire to - side of battery for ground and the third wire went to keyed on power. I would take a pic but I'm away from my bike working. I'll be home in a week. If you have no lug pm me and when I get home I will take some pics for you.
Good Luck
Good Luck
Check wiring harness along side front of gas tank. Both sides should have a white connector with the three wires you need. You will have to get the other half of the white factory connector and terminals from your HD parts dept. to upgrade fairing wires. Once you locate white wire connector on your bike,check it out with a test light to make sure.
Update
Good Luck
Good Luck
