EBC Brakes Pads
Old 03-11-2019, 03:48 PM
fenwick's Avatar
fenwick
fenwick is offline
Default EBC Brakes Pads
I am replacing my brakes with EBC. I know in the past when replacing with Harley pads, the back brake pads come with paste, do I need to use this or not worry about it. If so what are folks using
Thanks
Old 03-11-2019, 03:59 PM
23Seven's Avatar
23Seven
23Seven is offline
Received 1,441 Likes on 658 Posts
EBC worked good for me but we’re squeeky as hell. I’m back to OEM
Old 03-11-2019, 04:00 PM
lightweight bob's Avatar
lightweight bob
lightweight bob is offline
Default SBS anti-noise brake pad shims
Thanks
What I use - anti squeal adhesive shims cut to fit the back of your pads.
Amazon Amazon
Old 03-11-2019, 06:45 PM
tc66nova's Avatar
tc66nova
tc66nova is offline
A small bead of RTV works well. The squeal is actually a high frequency vibration that RTV or shims usually absorb.
Old 03-11-2019, 06:47 PM
Brewmany's Avatar
Brewmany
Brewmany is offline
I put on EBC's a couple years ago, and unless there was some goop included in the packet, I didn't use anything other than what they included.
Old 03-11-2019, 06:57 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is online now
Received 7,166 Likes on 3,675 Posts
I put disk brake grease on the back of mine, I also clean my pins or replace them and use the same grease on them as well..I only use EBC.
Old 03-11-2019, 07:02 PM
QAfred's Avatar
QAfred
QAfred is offline
what he said, thin film of high temp brake grease is all you need, Permatex makes a spray which works well too. Spray on back of pads, let it sit 30 minutes and you'll never hear a squeak from pads floating around.
Old 03-11-2019, 07:48 PM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
Ebc made alot of noise on mine too even with grease on the back. I also cleaned all the other crap. I went back to stock shortly after
Old 03-11-2019, 09:06 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,530 Likes on 1,425 Posts
A light touch of anti squeal on the back of the pad, and a light lube where the pads glide on the sides.
If someone does nothing but replace the pads dry, they deserve squealy brakes.
EBC is what I use, and never a problem.
Be sure to use what is compatible with your rotors.
Old 03-12-2019, 05:18 AM
foxtrapper's Avatar
foxtrapper
foxtrapper is offline
Veteran: National GuardVeteran: Navy
Received 1,665 Likes on 1,084 Posts
EBC Double H sintered pads and no noise.
Quick Reply: EBC Brakes Pads
