Haedlamp and spot lights inop.
Hey all. I have a 2013 ultra limited. I replaced the bars and extended the wires myself. Yep, it's one of these posts. Everything works, except the headlight and spot lights won't come on. I did check all of the fuses and they're good. I checked the connectors and they seem to be all connected. I'm out of ideas. Any body have any thoughts? I did try to follow the wiring diagram, but I got lost. That stuff is tricky.
Thanks in advance.
Thanks in advance.
It starts and runs. Throttle works, heated grips work, turn signals, horn, run stop stitch, brake lights and running lights all work too. Just no headlight or spot lamps.
That wiring diagram in the manual confused me. I'm not great at reading those. I tried to follow the wires backwards but they combined with another wire loom and I couldn't follow them any further. I might have to do some more tear down to trace the wires. Thank you.
Ok. I've been going over this wiring diagram. Can anyone say if this sounds accurate? It looks like a blue wire carries power to the hi lo switch. Then power is sent out from the switch. It seems like a thicker wire would be needed to carry power to drive the headlamp and spots.
Forget wire gauges. You're getting off track. Did you remove the inner fairing cap housing that contains all your switches (fog lamp switch, speaker control switch, cruise control switch, accessory switch). If you did, did you plug in the harness?
As far as the high beam/low beam switch, there is power to that switch all the time when the ignition switch is on. Power comes through the headlight fuse (15A) from the lighting relay, initiated by the ignition switch. Did you remove the ignition switch?
