1997 Electra glide classic true duals
[QUOTE=masterofyard;18089559]Will I have any type of trouble with the bike running due to the change of the exhaust. I know the MM f/I is a pain with change.[/QUOTE
when I bought my bike it already had the k&n air cleaner and the TFI fuel controller. I added V&H dresser duals and Rinehart 4" slip ons. I also upgraded to gear drive cams and so far no issues.
As far as I understand you should be just fine with your set up. I would go on the power commander website and download the fuel map that most closely matches your set up. Should be all good.
From what I've read the MM system becomes an issue when you start upgrading the motor with more displacement.
SgtCapNCoke
Milwaukee Eight (M8)
05-20-2019 10:26 AM
toddincharlotte
06-08-2015 10:13 AM
