Start but dies in a few second and won't run.
Good evening guys I am having a problems with my 06 Street Glide. My problem started after I filled up my gas tank once it was just above 1/4 tank. I rode for about 10 miles then parked my bike in the garage for about 3 hours. Then I started the bike up and then it began to run rough and back firing. Then it would start but it had no power and wouldn't stay running, I thought I must have put some bad gas in it , so I drained it out and put fresh gas in it. But it still wouldn't stay running, however it starts a run good for about 30 second and cuts off. So I did a diagnostic check and got some codes which has since disappeared. I had several codes, P0122, P0373, P0374, P1356 and P1353. So what I did was replaced the CKP sensor. I also check all the fuses and the battery is fully charged. I also changed the fuel filter and it still won't run but it still starts. So can any one tell me what I may have missed checking. I am asking before I take it to the shop. By the way I am find any codes when I do the diagnostic check.
I hope that I am not doing anything wrong by asking for help here. I am new to this site and if I am wrong I do apologize.
Received 1,684 Likes
What fuel filter did you change... my 07 has gone through 2 fuel pump plastic housing repairs, they crack and wont hold pressure. Dealer can do a fuel pressure check.
If your fuel level is low, open cap and listen for spraying while the fuel pump pressurizes when you turn ignition on.
Did you replace acordion hoses that come with filter kit? May be air sucking in to line. They have had issues with this happening. Easy to replace. Go to parts store and buy small pair of wire cutters and grind down cutting edges on pliers and crimp new hose clamps with them. Works like a charm
quadhauler
03-13-2007 12:04 AM
