Harley clock mount, hemisphere and IO mount magnet. I just change the case on the phone when I ride and mount the PV when I tune. Never had a device come off in 20K+ miles and too cheap to pay Klock Werks pricing on their perch IO device mount.
Just installed the Ciro phone holder on my throttle side this week. Quite pleased with this product so far. No blocking of mirrors or controls like some feedback seemed to indicate.
Here's pictures of the Rokform mount... I also have a cable run through my speedo/tach nacelle that connects back to my headunit. It's hard to tell in the pictures, but all of my gauges and headunit are fully visible while on the bike. No obstruction of view for any of them.
Thanks for all the replies. Keep em coming folks. LIke I said, I don't want to mount to the bars or mirror or whatever BUT I want to see your solutions. I am sure I am not going to find exactly what I want and will have to put something together. I am betting I am going to end up with a mount base from one place (might have to make it) and then a cradle/case from another.
I do like the idea of that Rokform thing because of the twist lock case. I am still not against the idea of drilling my fairing to solidly mount a solution if I can identify/design something that will be useful and somewhat form fitting. I like the idea of the Rokform that is locking (sort of) and makes it easily removable. But I also like the RAM mount as if I use the right combination I could remove almost everything except for the smallest of bases.
I have the fairing apart now for a stereo upgrade so I am wanting to figure something out before I completely reassemble.
Ciro 3d fairing mount, with their phone holder. Dead centre on the fairing, no drilling, and convenient for power supply.
I have seen a couple of this type. I am quite curious on this and wondering how it works with a set of windshield bags.
also wondering how big is the ball on the end of that? I wonder if it would be compatible with others like RAM.
I am wondering the same. I'm guessing that these gadget mounts are like holsters - keep buying until you find the right one.
Skim over the Rokform site...you may find something that works for you. They have a lot of mounts that are applied with 3M VHB tape. When done properly, that stuff is ridiculously strong, especially if you use the 3M adhesion promoter.
Also, the Rokform mounts have magnets built in. Not only does it twist-lock into place, but there is a magnet below the twist-lock in the mount and the case. So really, it's like a fail-safe, if you will.
I use the Kuryakan Fairing Tech Mount. Attaches to the fairing so it doesn't take up space on your handlebars. I've used it for a couple years with no problems. No drilling or modifying your fairing. Easy to install and remove. Hold my Samsung Galaxy S7 nicely.
