Battery Tender Flashing Green
It needs to read a voltage so it knows what to do. Been three months since I have been home but I thought unhooked, it went to flashing yellow.
Know if you put a meter on it, it will show nothing.
The solid state control is very sensitive to prevent overcharge.
Leave it on your new battery overnight. Bet all is good in morning.
However if old battery had a dead short, it could have damaged it I guess.
On mine. Should be flashing red when not hooked to a battery. Turns red when hooked up to a discharged battery. Flashes green when hooked to a battery 80%+ charged, stays steady green when battery is fully charged. I've got about 1/2 dozen of these things hooked to two bikes, boat, jeep, ATV, lawn mower and a spare that the light quit working on but charger still works.
I just went through this about a month ago.
Went out to the garage to get something and noticed my nine year old HD battery tender, which was plugged into the bike, flashing green. This tender had what the different colored lights mean actually printed on the tender itself. Flashing green meant 80% charged. I checked it the next morning and it was still flashing green. Battery in my bike is 18 months old. I unplugged it from the bike, but left it plugged into the wall. It still flashed green.
I hooked it up to a buddy's bike overnight. It was still flashing green the next morning.
Bought a new tender. All is fine.
The following 2 users liked this post by nascarfan:
HM_SanDiego (02-28-2019),
red sport. (02-28-2019)
Not sure if they're making them differently through the years.
When mine is not connected it is flashing orange.
When it's charging a battery that is somewhat low it remains solid orange.
80% charged it is flashing green.
Fully charged is solid green.
I have two bikes and move it back and forth every week.
Any reason for NOT including that information in the first post? I got the impression you couldn't read or were too lazy to read the instructions. NOW, I expect those with the same charger will be happy to help.
Received 2,530 Likes
Time to replace it.
When plugged in and connected, flashing green means 80% charged.
When plugged in and connected, solid green means 100% charged/maintaining.
When not connected and it's flashing, sorry, it's bad. Save the cables and ends, then throw it away.
I have an HD Smart Charger, and put a digital readout on top of it to watch what it does. When it first comes on, it hits near 14 volts to charge, then when it gets the battery up around 13 volts, it goes to 80% flashes, then maintains between 12.8 and 13 volts.
I put a readout on a friend's charger last year that flashed green all the time when connected - it stayed at 14 volts and never dropped, even on a known good battery. Trashed. Sure, you could have charged with it, but it would not "Step Down". No good for maintaining.
BTW - those chargers are now over priced. I also have a Foval Maintainer from Amazon for my boat that does great on the batteries. I stuck a digital readout on it too, and the numbers are the same as described above.
HINT: Do all you can to keep them COOL. They tend to put off some heat on the back side. I have mine plugged into a big extension cord and in a small wire rack suspended below a shelf. I have a 25' Deltran cord on it to reach anything it needs to without dragging it around. When they are plugged into a flat wall plate, the entire flat bottom of the charger gets hot with no air to cool it, thus the extension cord I use for it.
It was not flashing green as the OP stated.
