1996 Road King fuel injected
Old 02-08-2019 | 01:05 PM
Coache27's Avatar
Coache27
6th Gear
Default 1996 Road King fuel injected
looking for a fuel tank check valve part #61408-95A
thanks,
Blaine
Old 02-08-2019 | 02:33 PM
Tarkus60's Avatar
Tarkus60
Veteran: Marine Corp
Old 02-08-2019 | 06:49 PM
im's Avatar
im
Hello and welcome.
When looking for a part it is sometimes helpful to contact a local dealer directly if it is not too common.
Maybe you have done that and we did not know.
A part such as that one would be odd to obtain used too...so i guess that is not what you want.
The dealer can also look in the system to see if another store in the USA has the part in stock.
Unusual that part is bad but it does happen but then again we have very little information available to maybe provide a solution.
What exactly is the problem?
Sometimes we get folks that join for a moment, provide minimal information and do not take full advantage of information available.
For example on the bikes with M & M fuel injection and 2 fuel lines under tank it is much more common to develop a leak at the fuel line metal swivel that is not serviceable but Goodridge makes a set of replacement hoses that are of very good quality..Goodridge part # HDFL005
Best of luck.
Old 02-09-2019 | 08:11 AM
multihdrdr's Avatar
multihdrdr
Looks like you just missed a couple
61408-95A Sold
Coache27 (02-16-2019)
Old 02-09-2019 | 04:40 PM
Coache27's Avatar
Coache27
6th Gear
It is missing, and no Harley dealer has one.
Old 02-09-2019 | 10:33 PM
im's Avatar
im
I would reconfirm with another dealer or maybe a fellow member that works at a HD shop can check computer for ALL USA stores.
If that is a fail then contact https://pinwallcycle.com/ for a used part.
Again, unusual since if a tank was removed to be replaced then part would be re-used.
Old 02-10-2019 | 10:10 AM
1997bagger's Avatar
1997bagger
Spent a lot of time yesterday trying to source one with no luck, also looked at damaged tanks on Ebay being cheap but the fittings was removed on all of them. When someone does a carb conversion these fittings are removed so should be one available but seems like everyone thinks the take off M&M system is gold and wants top dollar.
With IM on this one, with Harley salvage parts companies having fuel tanks for sale on Ebay and the fittings are removed, they are selling the fittings outright, Pinwall is fair on prices but not the cheapest but may not have a option at this point unless someone who did a carb conversion shows.
Old 02-16-2019 | 03:19 PM
Coache27's Avatar
Coache27
6th Gear
somebody finds one please let me know, sure would like to get dad's bike going again
Coache27@yahoo.com
Old 02-16-2019 | 09:18 PM
mark681137's Avatar
mark681137
Have you tried the evo forum? I had a 97 with the same deal. They know that stuff over there.
Old 02-17-2019 | 09:02 AM
Plow64's Avatar
Plow64
Call these guys at 888-474-6435. They may have an aftermarket part that will work for you.
http://www.pingelonline.com/prodcat/fuel-valves.asp
Quick Reply: 1996 Road King fuel injected
