Adjusting Spark Advance
Old 01-27-2019 | 03:53 AM
23Seven's Avatar
23Seven
Default Adjusting Spark Advance
Any PV guru's care to help me out with adjusting my spark advance to help the bike start easier? Numbers seem a little high in the upper right??
Old 01-27-2019 | 07:41 AM
tv7son's Avatar
tv7son
Veteran: Marine Corp
When I was tuning my 11 limited with 255 cams I went to WOT(100%) 750 and 1000 RPMs and dropped 1 degree in each cell. I'm not so sure if the 1000 cell really needed it, you could add or remove to see the diff when starting.
I had 255 cams they are hard to get the engine turning and what I did cured it.
There is a memo out some where stating that "on start up the ECU puts the timing at WOT 750 rpm's until started".
I was using a HD Super Tuner. I see your timing cells at WOT are quite a bit higher than mine were, so a reduction of one degree at a time would be in order.
I think you are sniffing up the right tree.
Have fun, and keep good notes.
The following 2 users liked this post by tv7son:
23Seven (01-27-2019), Sam2010 (08-15-2022)
Old 01-27-2019 | 04:29 PM
23Seven's Avatar
23Seven
Another forum member with a similar set up just sent me a MAP to compare... I’ll make some adjustments and see how it goes.
Old 01-27-2019 | 06:33 PM
vbx07's Avatar
vbx07
Default Quick tune
I used the quick tune feature and went to -2 on low end of scale. My bike starts right up
Old 01-27-2019 | 10:25 PM
23Seven's Avatar
23Seven
Worked like a champ! Fires up as soon as I hit the starter... Went for a ride and let it idle for a bit in the garage when I got back. Engine temp wasn’t as high as a 100° day but still fired up quick when I hit the starter.
Thanks for the help gents!
Old 01-28-2019 | 08:22 AM
GalvTexGuy's Avatar
GalvTexGuy
Can you highlight in your graphics which numbers you changed? Did the 96 motors not come with ACRs?
Old 01-28-2019 | 08:29 AM
caulk04's Avatar
caulk04
No, 96" did not come factory with ACR.
GalvTexGuy (01-28-2019)
Old 01-28-2019 | 04:30 PM
23Seven's Avatar
23Seven
No ACR’s.
Dropped everything way down in the 750-1125 RPM and 70-100 KPa Range.
Super fast starts now... We’ll see what happens this summer?
23Seven
The Dyno Room
02-02-2019 08:51 AM
DeneFXDWG
Engine Mechanical Topics
56
11-20-2018 05:23 PM
Smu
08-30-2018 12:24 PM
jaxdwg
08-22-2018 02:25 PM
T Man
05-13-2018 12:48 AM
Quick Reply: Adjusting Spark Advance
