Vented versus non vented lowers
My tourer is an 02 Ultra and it has non vented lower fairings. They are great when the air temp is 69 or less, but if the air temp is any higher the heat reflected is really bad, which is why it's unbolted in the summer. Recently I've been looking at getting some vented lowers but wondering if they are really worth it. In my area the high temps in the summer get in the nineties. In the spring and fall, you can have morning temps in the fifties and afternoon temps in the seventies. Obviously vented lowers would be better, but would they work good enough to leave them on all year round? Or am I just going to be unbolting them anyway in the summer?
I have had both and really do not notice a difference (my guess is with vents open engine runs hotter?). I actually have no idea if the vents are open or closed unless I look. lived out in the valley where it is often over 110 in the summer and lowers stay on year round.
My Rig did not come with lowers, one of the first mods I did after windshield, pipes and headers. However just as my luck would have it, after ordering my Non Vented Lowers. They changed the fairing mounting bracket for the FLTR models in 2010.
Long story short, I keep my lowers on year round. They have been off once in 10 years for about 2 weeks when I upgrade my motor to 117" build. (In fact, my 117" motor runs cooler and stronger then when it was a 110" motor.)
Non Vented Lowers work great for me.
YB
Maybe look into finding a kit to add venting to your fairing lowers? Something like the Hoppe Industries Airmax Vents AMX2. I'm not even sure these are still available.
https://www.powersportparts.net/i-25...%7Cyear%3D2011
http://www.directcycleparts.com/tour...yABEgISifD_BwE
https://www.dragspecialties.com/prod...umber=23500008
I've found benefits to be subtle in hot weather. I've been riding for hours in hot weather with the vents inadvertently closed and gotten slightly better cooling by opening the vents. However, while it may seem counter-intuitive, the most effective relief I [and my passenger wife] have gotten was when the day turns cooler [such as after the sun goes down in early Fall - if you slightly crack open the vents, the air blown over the engine will actually provide a little warm to your legs and lower body.
YB
