Front Caliper leaking after changing pads?
Old 12-22-2018 | 09:23 PM
BadDogBiker's Avatar
BadDogBiker
Default Front Caliper leaking after changing pads?
I just changed the brake pads and the curbside caliper is leaking fluid from the top bolt that holds the two halves of the caliper together. Everything went smoothly until I pump to brakes to set the pads, must have pulled the brake lever at least 50 times before I seen the puddle of brake fluid under my tire, the front brakes just never wanted to stiffen up.
Is that a sure sign of a busted seal? Is it repairable for not a lot of money? I really can't afford to buy a new caliper.
2016 Road King
Old 12-22-2018 | 10:36 PM
Riffraff123's Avatar
Riffraff123
Not totally sure about the newer bikes, I ride 2000 Heritage. I rebuilt my front caliper for I think $25 worth of parts. I bought a kit. Did you maybe loosen wrong screws that hold caliper together instead of pad pins? If so, simply split cakiper, clean fluid off and retorque, rebleed.
Old 12-23-2018 | 08:41 AM
GalvTexGuy's Avatar
GalvTexGuy
There are aftermarket rebuild kits. Harley-Davidson does not sell rebuild kits.
Old 12-26-2018 | 10:38 AM
BadDogBiker
I found the rebuild kits, but they include the pistons and mine are still good. Would anyone be able to tell me the size o-rings contained in the front caliper? I work in a shop and should have the o-rings here that I need. Would save some money.
Old 12-26-2018 | 10:45 AM
GalvTexGuy's Avatar
GalvTexGuy
Old 12-26-2018 | 11:18 AM
BadDogBiker
Old 12-26-2018 | 12:19 PM
GalvTexGuy's Avatar
GalvTexGuy
I gave you a link to purchase the seal kit. Is that not what you need?
I don't know what kind of o-rings you have in your shop, but you do know that there are many, many different types, sizes and diameters of o-rings and some will react differently to a given fluid? I don't know about you, but I wouldn't take a chance on my brakes by installing a component that's not specifically made for brakes.
The following 2 users liked this post by GalvTexGuy:
nytryder (12-26-2018), Uncle Larry (12-04-2020)
Old 12-26-2018 | 12:22 PM
Schex's Avatar
Schex
Try tightening all the bolts holding the caliper together.
Old 12-26-2018 | 01:22 PM
strych9's Avatar
strych9
Confused about the location of the leak. You said where the bolts that hold the halves together? Which one? Had you removed them for any reason?
Old 12-26-2018 | 06:07 PM
Ben221's Avatar
Ben221
Did you accidentally loosen the caliper bolts that hold it together?
Quick Reply: Front Caliper leaking after changing pads?
