Love how the first thing every body jumps on is bleeding the brakes, alway start with the simple **** first peeps like pads then dig yourself a deeper hole....
Yes I have abs. When I press the pedal it goes all the way to the bottom with out slowing the bike. Should have included that I also tried replacing the pads.
You should have included EVERYTHING about the brake system you could think of, the pedal going all the way down is a key symptom, can only be one of three things, no fluid in the reservoir (there is a leak somewhere) or a failed master cylinder (normal level of fluid but pedal goes all the way down) , or air in the system (from a leak or something YOU did). One other RARE possibility is the pedal linkage disconnected from the MC push rod.
You either have air in the system or a bad master cylinder. Replace the fluid and bleed the system as a start.
You're going to need a trip to the dealer then. No matter where the issue is, it's going to require a bleed and with ABS, that means a trip to the dealer to do it right.
