Road King Custom Front Brake Noise
Old 07-03-2007, 04:14 PM
MOTOWN RIDER's Avatar
MOTOWN RIDER
MOTOWN RIDER is offline
Default Road King Custom Front Brake Noise
I've had my '07 RK Custom for less than a month and within the first 100 miles of riding I got front brake rubbing noise. Talked to other RK owners that I know and they say this is common for the RK. No one mentioned this before I purchased one... So I took the bike to the dealer andwas told the same thing. They said to give it time to break in and it should get better. Is this trully common and is their anything I can do to make go away or at least get better...other than going tofloatingbreak system?
Love the bike hate the noise...
Thanks in advance for your suggestions and comments.
[IMG]local://upfiles/33467/5D85991EFD1A4AE48983D54BBBBFB910.jpg[/IMG]
Old 07-03-2007, 04:48 PM
milz's Avatar
milz
milz is offline
2nd Gear
Default RE: Road King Custom Front Brake Noise
I get brake noise on my 07 RKC also. I only notice it if I pull in the clutch and glide to a long stop and there is someting on the side of the road like trees to reflect the noise. Otherwise I never hear it. Usually the road noise from trafic is much louder and I never notice it. Overall I would not say it is bad, I am pretty much indifferent to it.
Old 07-03-2007, 04:59 PM
joe v's Avatar
joe v
joe v is offline
its normal 05 rkcustom thats just the nature of the beast
Old 07-03-2007, 05:01 PM
MOTOWN RIDER
I guess the only thing to do is make the bike louder....Thanks
Old 07-03-2007, 05:11 PM
electra trike's Avatar
electra trike
electra trike is offline
Try this pull the front brakes off and file down the rear of the brake pads on a 45degree angle this takes off the sharp edge off the pad. Then use some scotch brite pad and scuff down the rotor on both sides. it works for a little while.
Old 07-03-2007, 05:15 PM
phatail9's Avatar
phatail9
phatail9 is offline
Stage II
I owned a 2005 RKC I was told to swap the front rotors ie; left to right and right to left, It worked like a champ!
Old 07-03-2007, 05:37 PM
rkcrwlr's Avatar
rkcrwlr
rkcrwlr is offline
Not that it will make you feel better, but I have the noise too. I read recently that the brake pad materials are higher friction/high performance and that the down side is noise is common. I know that more aggressive pads on m Jeeps have made similar noise. They also eat the rotors faster! Price we are going to have to pay I guess.
Old 07-03-2007, 05:47 PM
Rico450r's Avatar
Rico450r
Rico450r is offline
ORIGINAL: MOTOWN RIDER
I had the same problem and I had the dealer swap the rotators from one side to the other. So the right side rotator went to the left side and the left side rotator went to the right side. That seemed to help a whole bunch. I still have a little noise but not this noise I had that sounded like a semi coming to a stop. Hope this helps.
Rico
Old 07-03-2007, 05:53 PM
KCBULLDOG's Avatar
KCBULLDOG
KCBULLDOG is offline
Never noticed on my 07 Custom.
Old 07-03-2007, 07:56 PM
casique's Avatar
casique
casique is offline
Mine started at the 400 mile point, but went away after another 50 miles or so. I just hit 1000 and no brake noise.
Quick Reply: Road King Custom Front Brake Noise
