Play in rear wheel
Old 12-04-2018 | 02:04 PM
kdtahiti's Avatar
kdtahiti
Default Play in rear wheel
Rear wheel moves one and a half inches before anything happens
Old 12-04-2018 | 02:27 PM
grbrown's Avatar
grbrown
Question
So?!
Let's make a fresh start. What model and year of bike do you have? What are you doing to measure this 1 1/2"? If you have the bike in gear and are turning the rear wheel all you are measuring is slack in the primary and transmission gears, between the tyre and crankshaft. Sounds about right to me.
Joe from So Cal (12-04-2018)
Old 12-04-2018 | 02:36 PM
Kingglide549's Avatar
Kingglide549
What do you want to happen?
Is the belt not moving?
What have YOU done to troubleshoot it?
Old 12-04-2018 | 05:35 PM
Jshopes's Avatar
Jshopes
They all do that.
Kingglide549 (12-05-2018)
Old 12-04-2018 | 07:01 PM
Wisenheimer16's Avatar
Wisenheimer16
WTF??? This is the most idiotic post I have ever seen. I am am idiot even replying.
Old 12-04-2018 | 07:49 PM
95th 1200's Avatar
95th 1200
This is as clear as mud. What are you trying to accomplish? What is the problem? How are you obtaining this measurement?
Old 12-04-2018 | 08:02 PM
TwiZted Biker's Avatar
TwiZted Biker
Gonna need a bit more input here bud ,what kind of bike ? it moves 1-1/2" how ? side to side , up & down ? Back & forth while in gear it's common just slack in the drive drivetrain.
Old 12-04-2018 | 09:12 PM
702's Avatar
702
I just fired up my Ouija Board and conversed with Sir Isaac Newton. He confirmed my thought that if the rear wheel in fact moves 1.5", something is indeed happening. He went on to suggest that the motorcycle be rotated 180 degrees to the right and try again, unless you're in Australia, you should then rotate it to the left.
Old 12-05-2018 | 03:27 AM
Kingglide549
Pass me the envelope, again.
Old 12-05-2018 | 05:11 AM
Cobra1's Avatar
Cobra1
forwards or backwards?..
Quick Reply: Play in rear wheel
