Adding 20w shock oil to air shocks?
Old 11-30-2018 | 09:49 PM
not yours's Avatar
not yours
Default Adding 20w shock oil to air shocks?
I read somewhere that you can drain the oil out of the factory air shocks and add 20w shock oil and it’s a much better ride. How do you do this because I’d like to give it a try if its worth it. I can’t seem to find any information on it. Just a little project and any help would be great. Thanks
Old 11-30-2018 | 09:59 PM
dawg's Avatar
dawg
not yours (11-30-2018)
Old 12-01-2018 | 04:14 AM
Cobra1's Avatar
Cobra1
20w might be be kinda stiff. I put 15w Belray suspension fluid and love the ride and I ride 2 up most of the time.
Old 12-01-2018 | 06:11 AM
TBagger's Avatar
TBagger
I did Belray 10w and it helped a lot. Jobs not that bad, you just need a small hand vacuum pump.
Old 12-01-2018 | 06:16 AM
smitty901's Avatar
smitty901
20w would bit a bit over doing it. What is in them is about 7W going 10 maybe 15 is a big change. There are several threads on the sight about ways to do it.
not yours (12-02-2018)
Old 12-01-2018 | 06:38 AM
Notgrownup's Avatar
Notgrownup
I also think 20w is to high 10 is what I used and I’m a big guy at 275 lbs, I might could have used 15wt but 10 was fine...Installed Ohlins coil overs and never have to worry about those crappy air shocks again.
not yours (12-01-2018)
Old 12-01-2018 | 07:09 AM
Cobra1's Avatar
Cobra1
FYI no vacuum pump needed. I just used a 50cc horse syringe I got from tractor supply. I have changed the oil for two friends also. Takes about 1/2 hour including removing and replacing the shocks. PM me and we can discuss my procedure. It is rather simple to extract old and inject 10 ounces of new oil in a 13 inch shock.
Old 12-01-2018 | 07:50 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Why not show the procedure to all
The following 2 users liked this post by GriffinDenim13FLHX:
1957buick (12-28-2018), not yours (12-03-2018)
Old 12-01-2018 | 07:52 AM
Notgrownup's Avatar
Notgrownup
I let mine drain overnight but still suctioned out with a vac.
Old 12-01-2018 | 08:00 AM
smitty901's Avatar
smitty901
I used a plastic mustard bottle worked prefect and was easy measure how much came out and put the same amount back. Lot of ways to do it.
Quick Reply: Adding 20w shock oil to air shocks?
