Adding 20w shock oil to air shocks?
Old 12-28-2018 | 11:28 AM
btsom's Avatar
btsom
I did a little reading and found that engine oil also works in shocks.. I have engine oil in my front forks and will see how it does as the temperature warms up. I have an 08 Road King and it just has orifices to regulate oil flow/damping, no valves. Newer forks are more sophisticated and may not need such a thick oil. 30 wt. did well in cooler weather but got a bit soft in hot weather, hence the experiment with 20-50 engine oil. Not only is there no consistency in shock oil viscosity from one manufacturer to another, I have never seen any multi-weight (temperature compensating) shock oil. I have 20 wt shock oil in the rear shocks and am happy with that, but will probably try 10-40 engine oil next if a change ever seems to be needed.
  #32
Old 12-28-2018 | 02:12 PM
wscott's Avatar
wscott
Originally Posted by not yours
I read somewhere that you can drain the oil out of the factory air shocks and add 20w shock oil and it’s a much better ride. How do you do this because I’d like to give it a try if its worth it. I can’t seem to find any information on it. Just a little project and any help would be great. Thanks
I did drain the oem oil (5w?) from the rear shocks omn my 09 FLHTCU and installed 10w shock oil(not fork oil!) whick did pi,mp-rove dampening & ride a lot.
Reason was the 2x thicker 10w shock/suspension oil improved dampening so much i was able to reduce the amount of air i had to run in rear shocks (esp riding 2up) by approx 45-50% to avoid bottoming out the shocks.
I also installed 1" lower progressive front fork springs (lowered rear shocks 1" too) and an mix of 70% std and 30% hvy wt Screaming Eagle fork oil too along with also installing 2 new Michelin C2 tires all at the same time which resulted in a huge improvement in overall handling & ride of the motorcycle.
That fixed the horrible mushy front forks esp dive when braking that was now mostly gone being much firmer but not too firm/harsh either and the rear didnt ride harsh anymore either with heavier 10w shock oil also being a bit firmer too.
So now with bike being firmed up on both ends along with the great handling new Mich C2 tires the bike is a pleasure to ride handling much better esp when hitting a bump or swell while cornering where it used to get loosey goosey and now staying stable in same road/handling conditions with the harsh ride now gone too.
BTW,I 1st tried a 50/50 mix of std & hvy wt Screaming Eagle HD fork oil which was too stiff & harsh at times being so stiff the front tire/wheel would bounce off the pavement which was scary when it happened when hitting a large bump while cornering so i dont rec using a 50-50 let alone 100% hvy wt HD shock oil in a touring FLHTCU HD which i wouldn't rec.
Happy motoring!
Scott
not yours (12-30-2018)
  #34
Old 12-28-2018 | 05:41 PM
SkyMaster1's Avatar
SkyMaster1
changed to 20W about a year ago and its perfect
  #35
Old 12-28-2018 | 06:39 PM
Sandcrab's Avatar
Sandcrab
Default Shock Oil
Here is a picture of the oil removed from my 2015 Limited rear shock. After 46,473 miles, I think it is in pretty good shape.
  #36
Old 12-31-2018 | 05:27 PM
not yours's Avatar
not yours
UPDATE: first off I’d like to thank Cobra 1 and everybody that posted on this thread because I really appreciated all the advise. Back to the begaining, I bought a pair of 12” adjustable OEM shocks knowing I was loosing an inch from the air shocks I had on my 2011 ultra 13”. I noticed a difference but worried about loosing the inch and that’s when I started with my project. $45 for a Mity vac, $15 Amsoil shock treatment and $5 for a measuring bottle vs $190 OEM adjustable shocks ( used ) vs the premium after market shocks. After going for a few rides with between 8 psi and 15 psi ( never 2 up ) I decided I liked 10 psi. Never bottomed out and I liked the ride. Bottom line, if you got the OEM air shocks and want a better shock start with a heavier shock oil, not to heavy, try it out first.
P.S. I have a pair of OEM adjustable shocks 12” centers for sale
HAPPY NEW YEARS EVERYONE, RIDE SAFE
XPress
2014-2023 Touring Models
19
04-25-2024 06:49 AM
Bill03E
06-30-2016 05:33 PM
rwven
02-25-2016 11:21 AM
justanotherjim
05-21-2011 07:13 PM
MNrider
08-27-2008 05:17 PM
Quick Reply: Adding 20w shock oil to air shocks?
