Dual-Bending Front Fork?
Hey, I’m in the process of changing my front suspension on my 2019 RGS. I just removed one of the fork legs and removed the inners. My question is how do you remove the dual-bending piston in the fork? I was hoping everything would have just came out without having to replace seals since it’s a new bike. So do I have to break apart the upper and lower legs to remove the piston and is it welded in there? Thanks
dual-bending piston
2017~ Current $1.00 "Premium" Suspension Bending reed system.
2017~ Current on left & pre-2017 on right.
I would suggest going over your manual again. Part #9 is a piston ring used when rebuilding your damper rod. A new bike does not need to be rebuilt like a new piston ring.
Thanks Howard that was my mistake. I’m going to install a Pro-Action Fork kit with a new damper rod, spring and spring spacer. I removed the internals out of my fork leg. The damper tube cuff won’t come out. Do I need to split the forks to take the cuff out and also remove the check valve? Sorry for the confusion first fork job I ever tackled. Thanks
