security key fobs ......
I purchased a 02 Roadking that has the securty system, but the person I brought the bike off of did not have thesecurity fobs. My previous 02 Roadking,the one I wrecked, had two security key fobs. Can I use my old security key fobs, from the wrecked roadking with myRoadKing? Would I have to go to a dealer for programing the Fobs or is there a method one can do themselves?
Try thisfor setting a security code at the top once programmed using the chart at the bottom.
1. Set run switch to off
2. ign to acc
3. hold both turn sigs till lights flash
4. use left turn signal to enter number by pushing 7 times
5. use right turn signal as enter key
6. repeat until all 5 are entered and you hit enter
lights should flash and you should be OK.
KEY FOB ASSIGNMENT
The key fob on TSSM motorcycles must be set so it will operate the alarm system on the vehicle.
This assignment must be completed with no pauses between steps greater than 10 seconds.
Turn the ignition OFF after all key fobs have been assigned.
The programming mode will also exit after 60 seconds has elapsed without detecting any fob signup messages
or turn signal switch activity.
Two key fobs may be assigned to the TSSM.
The first successful attempt to program a fob will disable all previously assigned fobs.
If a second fob is to be programmed, it must be done in the same programming sequence as the initial fob.
2. ign to acc
KEY FOB ASSIGNMENT
![](https://www.hdforums.com/upfiles/2318/BA7FE9570903417D8FFD8F899B8F7EF5.gif)
