WO515 10” Mini Ape
Old 10-13-2018, 04:58 PM
23Seven's Avatar
23Seven
23Seven is offline
Received 1,441 Likes on 658 Posts
Default WO515 10” Mini Ape
I was thinking about going taller on my bars and then....
I kicked the Bars pretty far forward probably 10° - 15° out of line with the forks and find that my arms are a lot higher. I don’t feel like I’m reaching down to the bars and after a quick 10 minute ride they seem way more comfortable.
I got a 45 minute ride to work on Monday followed by about an hour and a half ride home. Lately it’s been messing with my shoulders and neck but I’m hoping this tweak to the bars will fix it.
Im pretty sure when the steeler had my bike a few months back they pulled them back more than I normally have them. That’s about the time I started to get uncomfortable.
Hopefully this works for now as I’m really not up for wiring up some taller bars.
Old 10-13-2018, 05:02 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 6,334 Likes on 3,182 Posts
Although the bars look nicer in line with the forks the more comfortable way is forward. So you share the strain between arms and shoulders.
Old 10-13-2018, 05:21 PM
23Seven's Avatar
23Seven
23Seven is offline
I agree so far... That long commute home with tons of lane splitting will be good enough to tell if I’m ordering new bars or not.
Old 10-13-2018, 09:50 PM
23Seven's Avatar
23Seven
23Seven is offline
Anyone else run these bars on a Road King? How’s the long distance comfort?
Old 10-13-2018, 10:54 PM
Dynamick's Avatar
Dynamick
Dynamick is offline
Not a Moderator!
Received 7,218 Likes on 3,430 Posts
For me, they're perfect. I also run them a little forward of the fork line.
Old 10-14-2018, 09:24 AM
23Seven's Avatar
23Seven
23Seven is offline
Nice Scoot... I got mine maybe another inch forward than you. I’ll post back in a hundred miles.
Dynamick (10-14-2018)
Old 10-14-2018, 09:33 AM
hbsoldier3's Avatar
hbsoldier3
hbsoldier3 is offline
Thinking of adding those bars to my 04 King. Or maybe, Wild 1 12.5" apes because I have a Cop seat which sits me higher.
Old 10-14-2018, 11:53 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
I can't comment on your bars but do agree that getting bars 'just so' can make a big difference to ride comfort on longer trips. It's quite fascinating to see and feel how the bars change geometry as they swing through the loosened clamps.
Old 10-14-2018, 07:53 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
I'm not sure if you're serious or being sarcastic. You foreigners are so dry.
Old 10-15-2018, 04:35 AM
Dguy's Avatar
Dguy
Dguy is offline
I replaced my stock bars with 8" Twin Peaks and just the change in hand position made a huge difference in comfort. More forward and wrists turned out a bit. The curl and position of the stock bars killed my shoulder blades. Doing it again I would probably go 10".
Quick Reply: WO515 10” Mini Ape
