Lowering 2017 Road King Special
Old 10-10-2018 | 06:39 AM
10Bones's Avatar
10Bones
6th Gear
Default Lowering 2017 Road King Special
I’ve been looking for info on lowering my RKS...unfortunately most of the info I have found pertains to the Classic or Custom models.
Looking to drop the rear 1”. Blocks? Shocks?
Already have plans to recontour the seat but looking looking for a little more drop. Anyone done this to this model?
Im 5’8” and about 155...bike fits me ok but looking for that last little bit to get the feel I’m looking for.
Any help is is most appreciated. Thanks 10bones.
Old 10-10-2018 | 07:01 AM
grbrown's Avatar
grbrown
The last thing I would do is lower the bike! For that 'little extra' you seek there are other ways to consider. The nose of your seat quite probably forces your legs apart when you put your feet down, but can be reprofiled to improve your reach. Another simple thing is to take a look at your riding boots and consider getting a pair with thicker soles and heels, to give you a bit of a lift.
As for being flat-footed, if that is your goal, it is over-rated IMHO - I have never been able to do that with most of my bikes over the last 50 years. You're taller than me and should be fine! Saddle time is the best way to improve your confidence....
Old 10-10-2018 | 08:06 AM
RK_Classic's Avatar
RK_Classic
mean city cycle claims they can drop you from 1 to 3 inches and narrow the seat pan on newer bikes, I would lean in that direction first and if you feel you need more I would go with 12 inch shocks.
rk classic.
Old 10-10-2018 | 09:55 AM
Redlegvzv's Avatar
Redlegvzv
I am 5'7" and change so probably a little shorter than you. I do fine on my Road King (Standard). Instead of lowering the bike you might take a look at a different seat. Or just thicker soled boots, as another guy on here suggested. Just my $.015.
grbrown (10-11-2018)
Old 10-10-2018 | 07:25 PM
EdwardK's Avatar
EdwardK
If you are already planning to redo the seat, wait until that's done before even thinking of anything else. Lowering the rear will change everything. Mainly ride quality and handling, for the worse. Change the seat if you wish and then get some good tall boots. grbrown is spot on that flat footing is over rated. 99.9% of the time your feet can easily be flat footed on the floor boards while you are rolling down the road. The other .1% of the time, you can use your toes or just stand up.
jlmcentire
06-13-2015 01:28 AM
rapp76
06-24-2013 07:34 AM
Dickard
05-31-2013 10:57 AM
Retread-NJ
07-11-2012 07:20 AM
mikecourthd
07-28-2010 08:32 PM
Quick Reply: Lowering 2017 Road King Special
