Engine Oil
Engine Oil
I have a 2000 FLHT Electraglide with 26,000 miles on it. Runs strong with no problems so far. I run Amsoil 20-50W and change every 4,000 miles. I recently changed my oil and filter and have about 600 miles on the new oil. I slightly overfilled and drained a few oz. out and noticed the oil was already Black. Is this from a dirty(carbon buildup maybe) engine? I know with several thousand miles that the oil will turn much darker but to be literally black so soon worries me. Any thoughts??....drifterfcrc
RE: Engine Oil
You have about 24 ounces of old oil left in the engine after draining, so it is not uncommon to have the new oil look a bit black.
Here's an option https://www.hdforums.com/m_95119/tm.htm
OR http://www.roguechopper.com/#
RE: Engine Oil
Most everyone on here is using some sort of synthetic oil. THe brand does not really matter. The natural oils will break down over time and lose the viscosity it had when new. The synthetic oils do not break down. The fact that your oil get's dirty is just a sign of two things, 1) There is always some old oil left in the oil system that you don't get out, thus the reason for changing the oil filter too. 2) The oil is doing it's job by removing the dirt from your engine. If the oil were to stay clean, then that dirt would have to go somewhere and that somewhere would be your drivetrain parts in the engine i.e. valves, pistons, etc...
Your on a great program for preventative maintenance...stick to it. I use the Harley oil, but I am thinking about switching to the Mobil 1 V-Twin Synthetic as it is 100% synthetic and not a blend.
Good luck and ride safe.
[IMG]local://upfiles/494/D8A667DE82744E20A66145CEA52D18E1.jpg[/IMG]
