U1097 Loss of speedometer serial data and weird behavior
Harley Davidson road king
103
543 cams
high flow air filter
jackpot slipons with competition baffles.
I recently had some work done on my bike to fix a compression problem, I changed the cams, changed the clutch and I added a fuelpak3.
The bike rides fine one day and erratically the next day.
U1097 - Loss of speedometer serial data
Could the loss of the speedometer serial data be causing the issues or is the fl3 faulty?
103
543 cams
- It seems to stall at 2000 rpm in first gear and then rides normal like it's not getting enough gas all the rest of the gears it rides fine
- Once in a while it stalls at 2000 rpm in all the gears
- It also seems like it shuts off one cylinder because the sound changes
- At a stop light it revved to 2000 rpm for no reason then after a minute or so it revved to 3000 rpm.
kamut
Engine Mechanical Topics
10-25-2011 12:24 PM
